1 - 19 of 19 Posts
So I have a fairly newish Bosh S4 battery and was curious how many V do you need to start a petrol 1.8?
I was chilling in the car with the ignition selected to electrics "I'' and the V dropped fairly quickly and coasted on about 11.7 - 8.
If say for eg. my V dropped to 10.00 could I still start the car? Is there a number I need to watch our for if that makes sense?
Also if I switch to ignition "II" the reading is also different I think a little less then what's on "
Reflex camera Digital camera Camera lens Camera accessory Camera
A fully charged battery is around 13 volts. 10 volts would be a flat battery and unlikely to start the engine.
What model and year is the vehicle featured?
Discussion Starter · #4 ·
13v? Isn't that when the cars ignition is on?
MK8 2006
Maybe the alternator isn't as good as it use to be
I am not sure its from the cigarette socket I would presume it reads the battery from there?
Maybe but I would actually measure the voltage at the battery to compare it against what is said on that display.
MY22 Jazz EX Hybrid
In the good old days a low battery would frank slower but would often start. These days all you get is a click with the 'check system' message.
At what V that occurs would be useful for diagnosis.
I'm quite sure during lockdown mine got lower than 11.8v and still started just fine.
Discussion Starter · #16 ·
What I will do is test ignition (off, "I", "II" and ignition on) using my trusty voltmeter and compare to the cigarette volt reader and get back to you's. I would have assumed the cigarette volt reader was accurate 🤔. I also remember starting my car on above 10Vs a long time ago..
das is right amps are more important than volts but if a battery is reading as low as 10 v id say a cell is down 12 volt batter 6 cells each 2volts per cell
modern bike batteries need to be around 12.8 volts to be healthy
1 - 19 of 19 Posts
