1 - 20 of 21 Posts
#MrGrumpy
The front lights are 72cm long (including the indicator) so I'd guess the 30x75cm would be enough? Eagerly await an answer as looking to do mine soon!
Bantersaurus Rex
Not done fronts yet but done the rears twice!
I ordered 2lots of 30x150 which gave me enough to do:
1 Centre Panel
4 Indicators
4 Brake Lights
(Wing Mirror Indicators)
Not quite enough in 1x 30x150 to do the full rear section would probably get one of those and a 30x45 for the rears...
Sorry cant help with front :(
Reactions: Syx
Bantersaurus Rex
PS Rear indicators are quite tricky do those first whilst you still have a razor sharp blade for the best finish, if you need any help drop me a message :)
Reactions: coste1l
Bantersaurus Rex
Ahh sound you won't need loads then mate I am going to get the Sumo Panel and the rest are flyeyed :) my flyeyed centre went today as I wanted the Sumo one!
thinking about the sumo vinyl for the centre section
I tried fitting mine today.
Ended up in the bin!
Very hard fit due to its size and trying to align it.
Bantersaurus Rex
scoosh did you spray your panel with soapy water first?
Sure did, a few drops of baby shampoo mixed in a spray bottle.
I started at the centre and tried to work out but its hard to see where to line it up because of the decals top sheet.
I ended up with creases all over and tore the vinyl trying to lift and correct it.
Bantersaurus Rex
Might try my CF Wrap instead then!
(Not sure if that would look a bit wrong though)
Bantersaurus Rex
costel! how much you ordering for the front lights?
Going to do mine soon after seeing Capticards at the weekend!!!
Bantersaurus Rex
cheers dude!
Dr. Evil
I'm gonna try the spray first, much easier, and if you don't overdo it there's no reason it should be a problem.
1 - 20 of 21 Posts
