1 - 13 of 13 Posts
Changing this for an aftermarket one
If I've understood the gaiter detaches by pulling down?
The gear knob unscrews.
I'll need to tidy the top of the gaitor to match. Am I pulling the large trim piece to the right of the gaitor away to take the gaitor off?
Yes, that's right. I seem to recall there is a screw at the top of the trim just by the dashboard. It's a bit of a tug but just pulls off. Replaced mine with a second hand alloy knob off a CRX
Discussion Starter · #4 · (Edited)
@rob.e any tips on removing this part of the trim^
Been eyeing it up but I'm nervous to attempt removing for fear of breaking it.
I can't see any screw holding it on.
the trim on the side by the drivers leg needs to come off first from memory. i think its just held in with clips, sorry so long since i did mine. just lift gently with a trim tool or similar to avoid damaging it.
once the side trim is off you need to lift up the base/ surround. pull that up to expose the underside of the gaitor and you'll see how its attached to the knob. yes the knob unscrews. from memory it was all pretty straightforward, did mine in about 30 minutes or so.
Discussion Starter · #9 ·
1 - 13 of 13 Posts
