This how to will allow you to connect a composite video source (DVD Player, Ipod video out, games consoles, Car PC and DIY reversing camera’s) to the built in navigation system This achieved by using the video in connector of the reversing camera accessory socket on all 3/5 door Civic’s with Sat Nav!
NB Composite video sources normally have a yellow video out RCA plug/socket…
Your video source needs to be able to switch to NTSC. (NTSC fits the Navigation Systems screen better than PAL). Normally found in a set up screen like this….
There are several threads on Civinfo with information regarding the connection of a video source to the Navigation System. (Links at end of post for reference).
In this How To, I have tried to combine the info into one simple guide.
This guide is aimed specifically at vehicles without the factory reversing camera. If you have a Honda reversing camera, see Jupido’s easy and comprehensive guide here.
Ok let’s get started…..
The first thing to do is get to the back of the Navigation Unit, this will take some time (Approx 1 hr 30 mins) and looks very daunting! Trust me, it’s easier than it looks, just take your time and see how it all goes back together.
Use this guide to dis-assemble the dash: http://www.civinfo.com/forum/79053-post1.html
I also suggest you consider doing the 'Switch on reversing cam manually' mod at the same time; this will allow you to switch on your video source whilst driving forward and will save stripping the dash down again later!
Once the Navigation is removed and you can see the back of it, you will see the green camera connector (Top left). The diagram below shows the pin outs for the socket:
We are only interested in pins 2,4,5 and 7.
Pins 2 and 7 are connected together, this ‘fools’ the navigation unit into thinking a reversing camera is fitted.
Pins 4 and 5 are the video part.
How you connect to the socket is up to you.
In my first install I connected directly to the pins of the navigation unit using a cut down ATX power supply cable (the metal connectors inside the plug on the ends of the cable fit the pins in the Navigation unit perfectly):
The cable colours corresponding pins where as follows:
Pin 1 Red Vcc 7v
Pin 2 Brown GND (Connect to Pin 7 Blue)
Pin 3 Not used Blank
Pin 4 Orange Video GND (White on Honda Kit)
Pin 5 Yellow Video + (NTSC Composite)
Pin 6 Black Shield (Not used - only for some Honda/Acura models)
Pin 7 Blue Camera detect (Needs to be connected to GND)
I know you can't see it, but my blue and brown wires are joined. I connected the RED to pin 1 as I planned to use the 7v to power a camera, but scrapped that idea.
This method is OK, but I decided to go for a more secure connection and used Gray 52’s method. This method uses a 7 pin 100kk Molex plug and pins (RS part numbers 296-4990 and 467-598 - you get 5 plugs, and 100 pins, about £8 in total.)
The last thing to do is connect a socket or plug to the Video + and Video GND wires. The easiest way is to connect a phono socket like this one from Maplin...
(Remember Video + connects to the central pin and video GND connects to the outer ring)
or you can do something more elaborate like Gray 52 here….
For further information, have a look at these threads….
A solution to connect DVD-Players and Game consoles to the Navigation Screen
[HOW TO] Manually switch on the Reversing Camera
Another aftermarket RV camera installation.
and for a bit of background re composite video in and wiring diagrams...
Rearview Camera.... pdf
For the audio in look here http://www.civinfo.com/wiki/index.php/Connecting_an_MP3_player
Thanks to Gray52, Jupido, Myago, PCR and Stef for their work on this.
Pin 1 Red Vcc 7v
