Thought I would share my installation of the Dice electronic iPod/iPhone car kit I took some photos of the progress just in case anyone may find them of interest or maybe even useful.
I got the kit form eBay delivered for £85 which I thought was quite reasonable, the kit comes with the dice box iPod cable and cable to connect the dice unit to the stereo, further to this I also installed the 3.5mm to 3.5mm aux cable as I had a spare one lying around.
The dice kit allows you to navigate the iPod while it is plugged in, it also allows you to skip through tracks with the steering wheel controls, I personally prefer to navigate through my music using the iPod rather than using the car stereo so this was why I decided on the dice car kit. Photos below show the installation.
To install the kit the dash needs to be taken of there’s a how to guide which shows you the steps although if you have small enough hands you do not need to pull the whole head unit out so do not need to do the first few steps.
Dice unit with all the cables including the 3.5mm to 3.5mm
Dice product number if anyone wishes to purchase the same one.
Connections on the dice unit
Dip switches this allows you to configure the dice unit to suit your needs, you can turn off iPod controls etc, another member on here pointed these switches out to me as I didn’t have a clue what they were until I got the dice unit, I thought they were on the back of the head unit when it was being discussed in another thread.
First off I removed the centre console arm rest there’s a few covers to pop off and some screws to take out then a sharp tug lifts it up, also discussed in another thread remember to disconnect the wire for the cigarette lighter before you pull the console out.
Next unclip the plastic surround around the gear shift unscrew the Knob and slide off this allows you to pull off the front centre console, before that you need to take off the dash below the steering wheel, this is easily unclipped see the “how to” guide on getting off the dash.
Once you have removed the dash you are left with this mess.
Not a good photo but it’s quite awkward here is where the dice unit plugs into the stereo and if you have small enough hands you can reach up and plug it in I was lucky enough to get it in on the first few attempts, although when I pulled my hand out it got a bit shredded so be careful of the sharp bits.
I screwed the dice unit on to a bit of plastic so it doesn’t rattle about however I discovered you need to move it behind that piece of plastic or the front console won’t go on right.
Now here is the point where you need to decide where the wires for the iPod is going to come out of I decided on the little compartment just above the gear shift, therefore I drilled some holes to allow the cable to pass into the compartment, I then cut it out with a craft scalpel. Feed the wires through and then put all the bits you’ve dismantled back together.
Here is where I have chosen the wires to come out of
Here is my hand after squeezing it up the back of the radio to plug the lead in, was worth a few cuts and scrapes so I didn’t need to take the stereo head unit out.
I’m not sure where I’m going to mount the iPod however got this cheapo car mount thing from asda was only £2.97, I think I may just keep it tucked away in the compartment as I don’t want to clutter it up with wires and mounts. Any suggestions on where to mount it would be good.
The END, the whole thing took around 30 to 45 minutes and is not difficult for those who like pulling things apart, I would also suggest when prising bits of plastic off wrap a flathead screwdriver tip in a small cloth to prevent scratches.
Ash
Ash
