1 - 20 of 42 Posts
Looking to start a mod thread but everytime i want a picture i use the manage attachments and it always posts the pictures very small at the bottom well if im going to do a mod thread i want have a picture in text and then write below it and so on.. So how do i do that if im taking thw images from my pictures on pc?
James
#MrGrumpy
When you've uploaded the attachment, copy the URL to that attachment and then surround it with [ img][ /img] tags in your main post.
upload them to something like Photobucket then copy and paste in the image tags, usually something like
Thanks guys :)
more torque than the mrs
[img][/img]
http://www.civinfo.com/forum/attachment.php?attachmentid=83028&stc=1&d=1357578714
[img][/img]
yes was wondering how to do this here it goes, if this works thanks if it doesn't more tuition
#MrGrumpy
Okay so, upload an attachment, like the one below.
Underneath the post it has the link to the attachment, copy the URL of this link.
Put the link in image tags and it will appear in the post.
Quote this post and you will see the tags.
[img]http://www.civinfo.com/forum/attachment.php?attachmentid=83040&stc=1&d=1357590943
[img]
one last try thanks for trying to explain syx[/img]
[/img]
#MrGrumpy
If I quote your post, I get:
[IMG] [url]http://www.civinfo.com/forum/attachment.php?attachmentid=83038&stc=1&d=1357619106[/url] [/IMG]
You want to remove the [url] and [/url] tags and get
[IMG]http://www.civinfo.com/forum/attachment.php?attachmentid=83038&stc=1&d=1357619106[/IMG]
Edit: For some reason the forum adds in a space that I cannot remove. "13576191 06" above should be "1357619106".
I'LL NEVER WALK ALONE
easiest way to upload pics...
upload as normal, then type your text.....then click on the little paperclip (this can be seen even if your not uploading pics) at the top, the image tag will appear and then click on it and it will appear under your text.....and you can do this for multiple pictures :D
#MrGrumpy
If I do that, I get this:
Rather than this:
that is true syx....i did say it was the easiest way :)
if i need to do a bigger pic i use imageshack and do as you described, but people can click on your image to make it bigger, maybe someone more computer gifted than myself can work out if this site will host larger images?
i dont get the url when doing the img tags but if i click on quote button it shows the url tags totally baffled .
#MrGrumpy
I'm guessing it's because there are spaces around the URL?
just a test
1 - 20 of 42 Posts
