1 - 20 of 65 Posts
HI Civvies,
My dealer kindly let me photograph the removal of a front door trim today. I want to add a speaker upgrade (not Honda)
and he was happy to show me how! Here are the pics.
Basically it's two screws that are behind little pop-off panels in the door handle and door pull, then the whole thing pops off!
It is hooked over a rim near the window so you have to lift it as you pull it.
I've also shown the removed speaker to give you some idea of how thin it is. It is really light too so not a brilliant unit!
Anyway, Enjoy!
Roger
Looks really cheap and nasty behind the trim don't you think??? Let us know what speakes you use, if not the Honda ones
Hi Mike,
It certainly does, you should feel how light the speaker is!.
I won't be doing the work until after half-term but I'll post some info when it's finished
cheers
Roger
Nice one Roger - great post!!
Does look a bit cheap behind but its the same with all cars!!!
J :D
great info mate cheers for that. will save aftermarket dealers a bit of time finding how to remove it!
Just wondering.....can anyone recomend some good quality (and reasonably priced) speakers that would replace the front ones? I didn't go for the upgrade option on the Civic cos it seemed to be a bit of a rip off.....
After seeing the step by step above I'd gladly have a go myself.
I am in the process of pricing up a Civic, and am really glad I came across the info on this forum. It seems that the standard fit speakers are pretty poor (at least comparing against my Current Golf MK5) - How do they actually sound in the real world.
I was before reading about the speaker upgrade option, going to specify this, but I now reckon I will fettle with it myself. One thing I did notice is that they charge you loads of money for some replacement front speakers, but don't upgrade the tweeters -??? Also the power input for the upgraded speakers is 60 watt, does that mean that you also get an amp increase for the fronts - Not that I can see. I reckon my inifinty components would fit in there nicely.
As far as the Bass system, that seems a lot of money - What I would propose is to use one of these 'compact' subwoofers in the boot - possibly below the floor, space allowing, and use the front left/right speaker to feed it - again assuming that the built in Head unit has not got a preout.
This would fill in the bass nicely, without sounding like a Halfords Chav, with your windows schaking. Oh and is probably half the cost of the Hnda system. Only bit of work would be running power to the boot, and extending speaker wires form the front speakers.
I have tried this arrangement in the past, and it make a HUGE difference to the sound. It means that even if you stick with the standard speakers, you will not need to push them as hard to get the low frequencies.
karlak,
I've done similar, but have always seemed to end up then replacing the fronts for something better as well. The std setup in the Civic actually sounds OK, subjectively better than the MK4 Golf and certainly better than the Audi. But I suspect the EX head unit is a lot better than the VAG items. The speakers look just like the crap I've pulled out of VAG cars.
I won't change the fronts until there's an adaptor available (I can't be bothered to make anything fancy) but I'll put in some nice high quality efficient components and take it from there - trying to avoid a sub (again) but no doubt I'll cave!
If you want to get a better sounding system, go with replacing the speakers front and rear with the coaxial upgrades.
That's my plan when I'm back from my hols in mid June. Not bothering with the bass amp 'though.
I'll let everone know what difference they make.
I have the bassworks, and coaxials in the front (I wasn't paying). Sounds okay, but not worth the money.
Are co-axials speakers with a tweeter in the middle? If so, I can't really see the point as there are seperate tweeters -correct??
Component speakers i.e. seperate woofers and tweeters will always be better than a "one speaker does 2 jobs speaker"
At least it seems like the stock headunit does a fairly good job. Still a shame that more and more companies are going for the bespoke fitted system. I currenlty have fitted an Alpine HU in my Golf, and to be honest the difference between that and the standard headunit is Just unbelievable - far more bass,better control of the sound, and you can actuallt hear bits of the music you can't as standard.
Please Manufacturers go back to a normal DIN size stereo, and ISO leads, so that we can upgrade if we wish..... Oh and no fancy CAN buses
There are dual cone, and co-axial speakers. The latter being the most expensive. The coaxials are good quality speakers. Probably the sort of thing you could source at a specialist import place for about £100-£125 a set. Honda charge £200 or so. I don't know if you can get straight swaps from a specialist.
Although a component speaker set up is preferable, I've heard a dual-cone, tweeter upgrade, bassworks set up VS a coaxial + bassworks speaker upgrade and the latter sounds best.
I wouldn't personally pay the £600 for the bassworks set up, pay the £220 or so for the coaxials in the back instead, if you want to improve all four main speakers.
Hope that helps a bit more.
The best Alpine I've encountered (7878 with its F1-Status drive, in the Golf below) was just ace. Serious money at the time, but an amazing sound (especially with a rather neat Boston Acoustics sub in the boot and some PG amps). Followed me around in a couple of Golfs, stayed out of the 350z (it had a Bose system and it was terrible) back in the Audi and now out of the Civic. Oddly, the system in the Civic is sounding almost acceptable - pretty certain that decent door speakers will make it just passable. Focals (again) I think!
Good news that the standard HU sounds so good - I have found my Infinity Component speakers out (thought I had given them away) and would certainly try and get them fitted in the front.
This is my current Golf with an Alpine fitted. No comments on the boring dash though :oops:
1 - 20 of 65 Posts
