1 - 11 of 11 Posts
Hi there,
This is a simple [how to] on removing the front grill on a Type R and other models.
TOOLS:
2X flat head screwdrivers
10mm spanner/socket
First of all you have to remove the front bumper:
http://www.civinfo.com/forum/how/69992-how-remove-front-bumper.html
remove the cover at the front of the engine bay by using the flathead screwdrivers and removing the 8 plastic clips on the top
Auto part Engine Vehicle Car Technology
This then shows the top of the grill housing. now you can remove the 2 10mm bolts on the top.
Auto part Vehicle Automotive exterior Bumper Car
Then again using the flatheaded screwdriver, push up and unclip the 4 plastic clips holding the grill in place
Automotive exterior Bumper Vehicle Hood Car
Just pull towards yourself and it comes right off :D
ANY QUESTIONS JUST ASK !!!
Discussion Starter · #3 ·
I do believe so !! all the grills are interchangeable, but there are other threads with more details on it !!
You don't have to remove the front bumper ? Just undo arches as you would as of you are going to remove the bumper? Then remove the screw at the top of the bumper behind the arch on both sides leave the underneath ? Unclip from near the wing & headlights & Pull the top of the bumper towards you as if you are removing it it will come away & you can get to the bottom clips ;) pull out grille as previously explained & replace with the grille you want ;) I did it this way to put my mugen grille on it is a lot easier ;)
Sent from my iPhone using Tapatalk ;)
Muscles From Brussels
Cheers guys lets hope all goes smooth ;)
Discussion Starter · #7 ·
should be a doddle mate. a monkey could do it ;)
just don't get back to me saying that you couldn't haha
I still managed to snap abit of the old grill couldnt figure out bottom two clips were clipped from the bottom durrrrrr!!!!!!!
But all in all took me 20 minutes max as i knew how to take the front bumper off ;)
Cheers for the how to really helped mate!
Discussion Starter · #10 ·
your welcome mate, began helped aswell lol ;)
1 - 11 of 11 Posts
