more torque than the mrs
Its stuck on but there are also two plastic pins with clips which are a bit of a nuisance. you may want to use and hairdryer to warm up the adhesive to help you out. I am sure you can get them off undamaged with a bit of care..good luck
R-398
In need of removing my grill fairly soon, how did you find the task? Did you have to drop the bumper?
was a little fiddly
what i did was open bonnet, remove plastic trim cover tops
remove 2 9or10mm screws, unclip top 2 grill retainer, the bottom 2 are the tricky ones.
one of mine was already broken, but it may be easier if you are removing the bumper as well?
