Things you will need:
A Flat Screwdriver
Driver Wiper Blade(P/N 76622-SMG-E11)
Passenger Wiper Blade(P/N 76632-SNA-A01)
Step 1: Lift the wiper arm up.
Step 2: Insert the screwdriver in the gap where the wiper cap is and gently move the screwdriver toward the top of the blade, this will pop the cap off.
It should look like this when you loosen the cap off
Step 3: Extend the wiper blade to allow you to press the lever that is underneath.
Step 4: While holding the top of the wiper blade press the lever and pull the blade down gently and the blade should slide off.
Step 5: Pull the rubber end of the end of the wiper blade where the word "TIP" is written on the wiper insert while pulling the insert out.
Step 6:Now you will also have the 2 insert reinforcement strips with that insert(DO NOT LOSE THESE)
Step 7:Now install the Reinforcement strips in the new insert.
Step 8:You may have to sit the strips before you slide the new insert back into the blade housing.
Step 9:Reinstall the blade into the arm and push up when it sits into the groove.
Step 10:After it clicks in, give a slight pull down to make sure it is locked in, then install the cap.
A Flat Screwdriver
