301 - 309 of 309 Posts
Well after a lot of jiggery pokery, tracing out circuit boards and reconstructing the circuit, I've got a schematic that works. I've drawn it in the falstad circuit simulator so you can play with it. It works as expected, with the mirrors retracting and extending with the central locking, and the button over rides it. Some interesting things... the circuit only works if the white wire is +12v all the time, independent of the ignition. It means that the arm rest button extends and retracts the mirrors even when the car ignition is off. Could someone confirm? I think it must be the case because else how could the car power the mirror retraction when the car is locked...? Anyway, I can't post links so google falstad circuit simulator and import the following text to build the schematic.
Code:
$ 1 0.000005 10.20027730826997 50 5 43
d 96 160 144 160 1 0.805904783
t 144 160 192 160 0 1 0.23077067282349617 0.5555457474008563 100
t 352 176 400 176 0 1 -1.929934980779688 0.6749157493922517 100
d 192 176 256 176 1 0.805904783
r 256 176 304 176 0 4700
w 192 144 400 144 0
w 400 144 400 160 0
178 176 256 256 256 0 1 0.2 0.021712419306605352 0.05 1000000 0.02 200
178 176 336 256 336 0 1 0.2 0.02171241930660535 0.05 1000000 0.02 200
w 176 368 160 368 0
w 160 368 160 304 0
w 160 304 176 304 0
w 176 288 160 288 0
w 160 288 160 224 0
w 176 384 160 384 0
w 160 384 160 400 0
d 128 384 128 288 1 0.805904783
w 160 384 128 384 0
w 128 288 160 288 0
w 160 224 400 224 0
w 400 192 400 224 0
w 256 240 320 240 0
w 16 320 176 320 0
w 176 320 176 336 0
w 400 144 448 144 0
w 448 144 448 320 0
w 256 320 448 320 0
w 304 176 352 176 0
r 352 96 352 128 0 1
w 352 128 352 176 0
x 309 115 331 118 4 12 fuse
w 256 272 448 272 0
w 448 272 448 320 0
R 16 144 -48 144 0 0 40 12 0 0 0.5
x 323 51 340 54 4 12 red
x 45 247 81 250 4 12 extend
x 37 339 71 342 4 12 retract
w 352 96 352 64 0
S 320 64 256 64 0 1 false 0 2
x 130 67 206 70 4 12 (igniton\spos\s2)
w 320 240 320 400 0
w 256 352 256 400 0
w 160 400 256 400 0
w 256 400 320 400 0
g 256 400 256 432 0
x 270 425 334 428 4 12 brown/black
x 401 182 437 185 4 12 BC635
x 143 194 179 197 4 12 BC547
x 269 42 305 45 4 12 extend
x 269 94 303 97 4 12 retract
s 128 48 208 48 0 1 false
w 352 64 320 64 0
g 256 80 256 112 0
w 208 48 256 48 0
x 465 73 493 76 4 12 white
d 448 80 448 144 1 0.805904783
x 465 113 480 116 4 12 D4
R 128 48 32 48 0 0 40 12 0 0 0.5
x -78 105 -2 108 4 12 central\slocking
S 96 160 16 160 0 1 false 0 2
w 16 176 -32 176 0
x 82 134 112 137 4 12 green
w 176 256 16 256 0
x 48 233 65 236 4 12 red
x 43 357 65 360 4 12 blue
x 15 131 63 134 4 12 unlocked
x 23 191 57 194 4 12 locked
R 448 80 448 32 0 0 40 12 0 0 0.5
g -32 176 -32 208 0
x -128 200 -49 203 4 12 Is\sit\sgrounded?
x 251 23 331 26 4 12 arm\srest\sbutton
Your drawing seems to be wrong because the mirror switch its base is connected to ground and not switching between ground and the other terminal.
If only OP wouldn't have taken down the drawings so that the people that don't want to buy a unit could still do it themselves.
