Wine and cooking !
Look at this Thread :
http://www.civinfo.com/forum/showthread.php?t=170&highlight=cruise+control
And you will found that :
It's the easiest cruise system I've ever used and in my car it works perfectly.
For those new to it or still waiting for the car:-
Press the inner most button (cruise main) to switch the system on.
Once at the desired speed press the down button part of the middle rocker button (Cruise set).
If you touch the brake or clutch at any time the Cruise will deactivate instantly. To resume at you last speed press the up part of the middle rocker switch (Cruise Res). the car will now gently accelerate up to the set speed again.
The right hand button is cancel. This obviously cancels the current cruise selection (same as pressing the brake or clutch). It does not turn the system off. To do that you need to press the Cruise main button again
If you wish to increase or lower this speed while the system is set at a speed you can press either up or down on the Rocker button. You can accelerate whilst in cruise to overtake but once done the car will slow down gradually to the set speed again, so the throttle does not increase the set speed (obvious i know)
The system will not work if you are even slightly on the clutch peddal or brake (I know people who rest thier foot on the clutch while they drive thinking its not sensing it, if the civic can sense even the slightest touch and if it does it wont active the cruise).
abu-sarta, it would help if you put your location in your profile - I have a suspicion that the EX coupe in your region may be a bit different to the 06+ Euro model.
And don't forget.
The Cruise Control will not activate below 27 mph.
"Laugh and the world laughs with you. Snore and you sleep alone!"
Charles H.
My car's better than your car![smilie=smack.gif]
"She said that she was approaching 40.
......but she didn't say from which direction tho'!"
Charles H.
