Fitted a hks induction having a few problems .. im bit of a newbie
1. Rattling against the heat shield , ( due to the bracket that came with it i cant seem to move it further away from the shield also sitting a little low down from other pictures ive seen) any ideas ?
2. Heat Soak ( car seems sluggish and at idle stalls instantly when clutch released a tiny bit , never used too )
3. with the heatshield i got a solid black cylinder thing , has hole in middle and size around 5cm length and 2cm width what could it be ?
Thanks in advance :)
Enjoying life
Have you tried pivoting the bracket? Make sure the filter sits perpendicular to the intake pipe so air flow is not causing problems at the maf.
