Hello to all!
Today I have said:enough to my speedo displaying -40 degrees or --- at me...
I could only turn my heater on full hot or full cold. Not to mention A/C not kicking in.
So, after a minute I located the sensor (thanks to the forum).
I didn't want to remove the bumper (too many things may go wrong ie clips, scratches and so on...)
Decided to tackle it through the lower grill mesh. And with help of two long screwdrivers- I succeeded!
So with my sensor in hand I hooked it up to the multimeter-no readings or some way above the limit (10Mohm; should be something around 1-2kohm at room temp.). I thought: ok, time for a new one...
After quick look I decided to try to open it up (nothing to lose, right?). There are two small clips on the sides, probably after assembly process, as after I opened those-it still didn't want to open. After a bit of help from pliers and phone opening tool (that's what I do at work...
) I managed to open it up...sort of...
No idea how the water got there, all connectors are sealed and tight, but I discovered total liquid damage inside (see photo). Two thin wires were corroded and one has no connection at all... Sensor is filled with silicone-like glue and at the end of the tube is the sensor itself (thermistor i reckon). With small screwdriver I removed all the filling and pulled out the sensor. Both wires were damaged but as turned out-solderable and sensor itself measured correct resistance.
So it's the matter of two thin wires that need to be soldered back to the sensor and to the terminals. After that done, I filled the tube with silicone (overfilled it so all connections are covered), ensuring that there is no air trapped inside and closed it back... Next day silicone was set and sensor went back to the car. Now I have beautifully-sensible 12 degrees on my dash
opcorn:
This is probably nothing like know-how but I decided to share my experience with others and to say it's possible... I saved 50 quid with an hour of work and there is so much silicone inside now that I don't think it will pack up again...
Thanks!
Thanks!
