I removed the sensor for a second at my airbox when my type r was running. Then the engine management light came on. When I put the sensor back in. The engine management light did not disappear. Is there anyway I can get it removed.
Cheers Glenn
Resident Civinfo Nutter
Try disconnect the battery for a few minutes?
Think I spotted ya the other week near shopping centre on the northway towards Portadown, I was at Lidl carpark ;)
disconnect your battery for 20-30 mins and that will reset the ecu. If anything to do with the ecu that should fix it.
Ok I'll try that. Thanks for the help lads. Neo my number plate is * liget g * probs was me' you seen. Was it a white type r. What are you driving now **.
Yeah it was the white type r, seen it before ;)
Im in a white CRZ now, with L88 as the start of my plate :)
Cockup Specialist
If that fails then its a garage with ODB to reset the warnings :thumbsup:
That done the trick lads thanks very much for the help.
