Hi Guys,
I recently noted that once my engine is warn, the idle is at about 700-800 rpm? There is no shaking or anything.
Ref its a 58 Plate Civic 1.8 ES Manual.
any thoughts?
I'd love to know this too ? I've checked my plugs and there fine air filter is good too . Take it it does it when cold as well as warm!?
Sent from my Robin using Tapatalk
Discussion Starter · #3 ·
I will check mine took over the weekend. No the RPM is above 1 when cold. in the winter time its like 1.5 and the drops down to below 1 and sit around 700-600 rpm.
very strange. the RPM hunts slightly when air con is on but then i think there is a ac leak as it doesn't blow cold anymore.
Discussion Starter · #6 ·
Ohh ok, i suppose its normal then. if i do see it drop any further i will let you guys know, thank you all for your input into this.
the ac system has a leak i think as its not blowing cold although relay has been replaced. hope it doesnt suffer from a vac leak. will let you know
cheers
