1 - 2 of 2 Posts
took the drivers side front wheel off to look at the tyre when i had finished tried to get in the car using the fob but it did nt work so unlocked the drivers door with the key and the alarm started put the key in ingition and turned on as far as pos 2 but could nt turn key to start position alarm still on got out closed doors and used fob no change locked with key no change disconnected battery and alarm stopped reconnected after 1 min no alarm fob working so opened tried to start but again key not going to start position never had this type of problem with hondas before so any info great fully accepted
There is no starting key position in 8th gen civics... It's 2nd position and the start button/
And alarm issue is quite common, you will need to get it out and replace the internal battery. Its located behind the boot right side plastics.
1 - 2 of 2 Posts
