Hi not certain if this will help anyone. But my 8th gen 2006 i shift battery went flat a day before my long trip south to Cornwall went and charge it for a few hours. Tried starting it the engine turned but wouldnt start. A key shaped warning light flashed on the dash and also siren was sounding off aswell so I thought it was just a reprogram the key. No it wasnf that it turns out that there is s fault that if you charge the battery or jump start with the key still in the ignition it makes the immobiliser not recognise the key. So i had to get a specialist out at the cost of £140 for ten minutes work just to get the immobiliser to recognise the ignition key. Is there an update to this problem?
MY22 Jazz EX Hybrid
This key in ignition problem has been posted here way back to 2006.
First one I found is mid 2007 :
I'm seem to recall there was a dealer update to prevent this happening.
