1 - 10 of 10 Posts
Hey guys,
I own Honda Civic FK2 2006 European model. I have a problem with my instrument cluster (that has RPM, temperature, fuel level and other warning indications) that its backlight goes off randomly regardless if the car is being driven or standing still. When I touch the instrument cluster's dimmer knob, the backlight comes on again. There are basically 3 screens in the dash and only one screen has this problem. You can take a look at the
for this problem.
I would like to know if anyone out there knows how to fix this issue ? would really appreciate your input. Thanks :)
Umair
Looks like either a loose connection on the back of the dimmer switch, or the dimmer switch is fecked mate.
I purchased a replacement 2nd hand cluster and it works fine. Just to test I used the dimmer from my original cluster and it still worked so it isnt a problem with the dimmer. Really stuck now as to what could be causing it
Hello.
I have the same issue with my 2006. 1.8 problem
Is there any fix known for this?
Can we dismount and sord some wiring or any bad connections?
1 - 10 of 10 Posts
