regas?
I get same problem with mine. Have had it regased and checked for leaks by Kwik Fit.
They say it may be the compressor switch and that I should get it checked by a specialist.
I've found that the AC only comes on properly if i flick the switch on/off a few times rapidly... but then it does switch off randomly while i'm driving.
Any solutions for this yet?
Are there air con issues I havent read?
My air con seems intermittent, sometimes it works for a while, then goes normal cool temp for a while.
I may have picked the wrong diagnosis for your problem, but if you have the climate control set to auto the air con cycles on and off to try and keep the temperature constant.
If you switch the air con on manually it runs all the time.
Have you tried running it manually.
