Hi All,
I'm sure this has been asked before but its wrecking my head!
I have an 08 Civic Hybrid with the dash mounted 6 cd changer.
I want an ipod connector instead.
I bought this: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
and installed it.
It charges the ipod fine but the radio will not pick it up as an input.
I press CD/AUX and it swaps over to the CD. If I have no CD's in it just stays on the radio.
I have heard that I might lose the use of the CD player. Thats fine.
Am I missing something?
Should this work or do I have a faulty unit?
Thanks for any input (No pun intended :))
Al
Unofficial Trader
okie dokie.....no worries. In my own opinion, either the connector is not compatible or it's faulty. It could either be your ipod is not compatible. Try a friend's ipod and see if it works. Finally maybe the connector is lose behind.
M
Discussion Starter · #5 ·
I've tried it with an iphone and ipod.
I've also re-checked the connection at the back. No luck
In theory it should work?
Has anyone else done this with the dash mounted 6-cd changer unit?
living the dream
Have you tried connecting the iPod/iPhone using the aux input instead of the iPhone cable? (I mean audio output from the headphone jack of the iPod/iPhone)
It could be the iPhone cable that's the problem?
Also presumably your cd changer worked fine before, did you have to press a specific button on the HU to activate the cd changer before?
The Honda aux in port (white plug) has a few different pin configurations,even though they look the same. Hence the original US xcarlinks people got from eBay back in 06/07 did not work with our Euro civics.
Having said that, your hybrid is based on the usdm/jdm civic, so I would have assumed that adaptor would work... Unless Honda fit a UK/Euro HU in the hybrid too?
Is it this one?
