May I ask what youre polishing the Honda with?Is meguiars 105 safe for the soft Honda paint or is it too abrasive?
Did you get the 105 with the kit you got for crimbo mate?Is meguiars 105 safe for the soft Honda paint or is it too abrasive?
Yeh I know the paint is soft. Going to be using my DA polisher with it.May I ask what youre polishing the Honda with?
Hand?
DA?
Rotary
What pads do you use?
How much have you polished before by any method?
Honda paint is soft and thin..I'm sure you know this
Nah mate but looking to use a good cutting compound to get rid of some of scratches and swirls in the paint and seen a lot of people talk about 105Did you get the 105 with the kit you got for crimbo mate?
I found 3m ultrafina and perfect it is better but you have to buy a big bottle thats the main downside. i even had to use a more aggressive polish then 205 on my NHB even after a couple of passes on the DA which is why i used 105 after, best thing is NHB looks perfect when your finished. Im no pro but i think with 105 and a DA your as safe as you can be as long as you have read up on a little of the basicsNah mate but looking to use a good cutting compound to get rid of some of scratches and swirls in the paint and seen a lot of people talk about 105
Thanks for the info mate. I have done a lot of reading and watching videos on how to use the DA. I also watched my cousin using his as he has done it for a few years now.I found 3m ultrafina is better but you have to buy a big bottle thats the main downside. i even had to use a more aggressive polish then 105 on my NHB even after a couple of passes on the DA, best thing is NHB looks perfect when your finished. Im no pro but i think with 105 and a DA your as safe as you can be as long as you have read up on a little of the basics
Handy to know that. Thanks.Just remember that Ultrafina has zero cut in it so any correction work was done by the pad not the product , its also regarded as one of the biggest filler polishes on the market due to the amount of oils in being oil based not water based so unless your wiping down with IPA you will be masking somewhat without knowing , you will only know once you start getting polish fall back when swirls will start reappearing and you may think your wash technique has created them when infact all the time the channels were filled.
Not in all cases but alot of cases....
