As per the title, is the fn2 bumper (the upper bit with the fog lights etc.) The same across the range. Reason I ask is I've had a mare 'experimenting' with mine today and can't find any fn2 type r specific bumper sections on eBay. Cheers
Not surprised you are having trouble finding one, it's the most likely bit to get killed in an accident.
If you have a later FN2 it will have the headlamp washers. So no they aren't all the same unless you find one from the EX or a version fitted with HIDs.
They are still available new at £195 already painted from Cox Motor Parts if you want to spend a lot.
They do come apart because I fitted a new splitter recently but it can be a game if anything is damaged.
Perfect. Thanks for that. Mine doesn't have headlamp washers so hopefully everything else is the same.
Register with Cox and get the Civinfo discount - might make some difference.
I have received a used bumper from a Non type R. Haven't had a chance to attempt fitment yet as i need it painting. It does look to be exactly the same though, so all good so far.
