Hi Guys,
For a while now I've had an issue with filling up my car with fuel. My car is the 2.2 Diesel 07 Reg Civic SE
When inserting the nozzle and starting to fill up, I only get about 2 litres in before the pump clicks off. I can then wait a few seconds and get some more in before it clicks off again, as if the tank is full, which it isn't.
If I pull the nozzle out a bit and slowly pump fuel into the car so I can see it going down, I see it fill all the way up to the top of the pipe and then slowly drain down into the tank, along with some air bubbles popping up through the fuel.
So my diagnosis is that something is causing the fuel not to drain into the tank fast enough, has anyone seen this before? It started as an intermittent issue which I just got on with but is now becoming an issue for every fillup wherever I go (so it's not the pump). The other day it genuinely took me 5 minutes to get 6 litres of fuel into the car, something which the guy behind me was less than impressed with...
Any thoughts would be appreciated. I contacted my local dealership and they said it may be the breather/filler neck and to replace it would cost almost £600
Regards,
Flobber
Regards,
Flobber
