Clutch was very stiff. Main dealer has replaced the clutch.
Going to first gear from neutral there is judder. There was no judder before clutch replacement.
There is a little vibration while driving.
Someone is suggesting it could be Flywheel
Others say gearbox mount
Seen a lot of posts in this forum but nobody posts the end result and how they solved it.
Hopefully some of you had similar problem and solved it.
Please share how you solved similar problems.
2013 MK9 pre facelift 1.8 TI. Eibach springs and spacers. Michelin PS4’s. Always run on VPower fuel
Generally down to not lining it up properly when they fit it. But agree, take it straight back and get them to fix it.
Take it back! Juddering clutches are an issue on the mk8, mine is hard to get off the line smoothly but I bought it as a 13 year old banger so obviously I had few comebacks.
Expect nothing other than a perfect clutch from a dealer!!!
