1 - 11 of 11 Posts
· Super Moderator
that is the most common ABS sensor to go on the 8G Civic.
cheap part bit of hassle to replace, unless you are good at mechanics best left to a garage
· Registered
2007 Honda Civic 2.2L Diesel
Discussion Starter · #5 ·
I have a Launch CRP123 unit that has reset capability with detail 2.3 inch screen I just lack the wiring diagram I am thinking of upgrading to Honda iHDS capable OBD unit
· Super Moderator
if sorted the light will go out by itself no need to reset to get rid of light but the code will be stored in ecu till deleted
so there is another fault
try cleaning the encoder ring on the hub/wheel bearing
also depends how the old 1 was removed the encoder ring might be damaged
the other is the wiring itself
harder to trace and fault find on this 1
if you can get a suitable code reader drive while looking at live data see what its showing
1 - 11 of 11 Posts
