1 - 16 of 16 Posts
Other than the engine obviously anybody know what is else if anything is needed to fit fit a K24 bottom end in the FN2?
250bhp.... finally :)
Check out K20a.org for K24 goodness :)
I am quite sure you also need FD2 oil pump, and Flashpro. If not going for aftermarket cams take exhaust cam from 2,4 as its better. Its a good time to also install baffled sump, 3rd/4th syncros, LSD, longer final drive, upgraded clutch etc.
And you will probably need new piston rings and bearings if reusing stock internals
it's enough to use K20a2 oil pump, for cams I would use OEM stuff K24a3 exhaust cam + Acura TSX 06-08 years intake cam. Also use VTC 50 degree gear. LSD and longer final drive +++ BTW I have spare almost new Wavetrac LSD with bearings and EP3 full gearing with FD 4.7 for a new owner :)
Thanks for the info guys.
I already have
Flash pro
Rrc inlet manifold
Tegiwa exhaust manifold
Fd2 oil pump
Lsd
Long 6 the gear and clockwise motion sump baffle as well as a few other mods.
Just got the car back from the insurance after the engine sucked in water. (Written off)
Just trying to decide if I invest money back in the engine or split the car up
For the ex header it needs to be adjusted to account for height difference
What caused the water issue, a low down cold air intake?
Discussion Starter #12
Yep Skunk2 CAI. I was sat in water just up to the bottom of the door when I wagon came round the corner full tilt and sent a tsunami my way :-(
CAI greedily sucked up a engine full of the stuff....
Any idea where I could source the Acura TSX 06-08 intake cam
" Also use VTC 50 degree gear."??
1 - 16 of 16 Posts
