1 - 12 of 12 Posts
I have a Type R GT and still struggling to get my K800i to work properly with the HFT. I am on the 02 network and I'm told I have the latest software. I can receive calls fine, but can't use either the phone's or HFT's phonebook to make calls.
I know some people have found a fix for this, but not sure if that was on a different network to me...? I have the following software / firmware details:
Current Software Version:
CXC1250210
R1CB001
060608
If anyone is able to help me with this, I would be eternally grateful.
Cheers. Adam
Hi I have a K800i on O2, if you are using the update service which is on the phone itself to check for a newer version it doesn't work. It will always say you have the latest version when you don't. I downloaded the Sony Ericsson software for updating phones from there website. You need a PC to run this on and the USB cable that should have come with the phone, after running that it updated my phone to the following version.
R1JG001 (that's the only part of the software version that matters really)
I have now done 5 others for people at work and not had any problems, it does not effect anything on the phone like contacts etc.
I still can't use the phonebook on the phone itself but that seems normal regardless of what phone you have after talking to others on here. It dials out fine using the HFT phonebook or you can dial from your phone, hang up very quickly then use the redial command with the HFT.
Hope that helps
Thanks.
I've done exactly what you've suggested a couple of weeks ago, which didn't seem to work - do I need to re-pair the phone with the HFT or anything before it will work?
Many thanks.
Hi I would try it again as they updated the software quite recently and the version you have posted is a few behind. I did my O2 K800i about 10 days ago and it has worked fine ever since. I did not have to delete my paired phone but it can't hurt.
buggar. think I've made this worse... I've tried the SE update service, but it came up with an error message so not sure if it has worked properly as my firmware is still the same.
And now, I can't connect the phone to the HFT at all. I've also tried connecting my girlfriend's phone to it, which doesn't work either. The nice voice on the HFT says "Timed out". I've even cleared the system to see if that helps, which it doesn't.
Anyone have any suggestions? Thanks.
I found it worked better if once the car was searching for the phone to pair to then set the phone to search for devices so they are both searching at the same time.
Hope that helps
Hmmm. Tried that too, but it kept on saying 'not allowed', etc. The phone does see it as 'Honda HFT', but obviously can't connect in that direction. The HFT waits for about 3 minutes before timing out.
Is there any other reason why it might not connect? Thanks.
I suspect you have already tried this but just in case, I usually delete the HFT from the phones devices, delete the phone from the cars devices, switch both the car and phone off and then back on and do the above of trying to get both searching for each other. That has always seemed to work for me.
Good luck
Has anyone had any issues with updating the Sony Ericsson software? I have tried this now on two PC's and hasn't worked - saying "update error - please disconnect and try again". I'm wondering if there is a problem with my phone itself???
Cheers.
hi
have just bought a new crv ex ctdi, same thing with the k800i, connected but kept transfering the call back to the phone, read somewhere that if you unbrand it and reinstall the software it works, tried it and yip it does work, i am on orange and the phone is slightly different, menus etc, but no problems as of yet, the site is http://www.wotanserver.com/
it cost you 7 euros (paypal)
you have to download a small programme, wotanclient, and run it from there, you need the software version R1GB001.
warning!!!!! i am led to believe it will void the warranty on your phone, but i can live with that as long as my HFT is working,
russ
My original K800i T-Mobile firmware wouldn't work properly with the HFT. The car would fail to pair, and initiating pairing from the phone wouldn't always work (the HFT would say something about pairing this way not possible). Once I did get it to pair, calls would ring on the HFT, but transfer straight back to the phone.
A couple of weeks ago, I used the SonyEricsson web update service which upgraded me to R1GB001. I think this firmware has been superceded a couple of times, but it fixed the HFT problem for me. My phone remains network locked.
1 - 12 of 12 Posts
