1 - 19 of 19 Posts
Hi I was driving my car to work for about 20mins then the stereo switched off including the dvd drive in the glovebox. When I parked up and went to open the doors the switch that opens the doors wouldn't open the doors and the key fob won't lock or open the doors anymore. Everything else still works like folding mirrors lights etc. I only have 1 key so can't check with another. :confused:
When did you last changed the battery in your fob?
What make of battery did you use? - Wardy often recommends high quality batteries as they are more reliable.
Hi thanks for the reply. I checked the door lock fuse and it wasn't blown but changed anyway and the door button is now working but only when the key is in the ignition. Also a red light comes on where the temperature gauge is for 3 seconds the goes off.
Hmmm
I know the SatNav/Radio fuse is one of the 7.5 jobs. It's highlighted in Pottsy's wiring in a Snooper post.
If you have had a few fuses blow then maybe water got in somewhere or a connector has worked loose at the back of the fusebox?
Only real way to check quickly is a multimeter as the fuses have an external check 'dot' so you can quickly run along the banks. Also make sure the engine fuse cover is tight.
No Smoke no poke
Hmmm
I was thinking the same kremmen I'd do a continuity test across all the fuses using the check dots as so many of the electrics are linked it could be anything 😨
Wardy
Sent from my HTC M9 and the power of my thumbs.
You could be right. I had the heko rain deflectors on the car and was getting a lot of condensation on the inside of the windows since fitted. I'll check all the fuses tomorrow. Also is there a fuse for the alarm can't seem to find it in the manual. Thanks
Just an update incase anyone has this problem. The backup fuse was blown and now everything's working.
'backup fuse', what's that then?
Glad you found and fixed the issue.
This 'backup' fuse is located in the engine bay, so doesn't seem related to interior condensation.
1 - 19 of 19 Posts
