So i have changed springs, struts, axle buhes and brakes on the rear on my fn2 and yet it still knocks, had the exhaust moving around vigorously , I have stripped out the rear drivers plastics and the boot floor and plastics,
It sounds like its coming form both corners down low, anything else anyone has found?
no mention of changing your roll bar bushes/roll bar link bar - have these been done?
when does the knocking occur - corners, speed bumps, single side pot holes...?
Sorry , i have done the drop links and ARB bushes, but the knocking is from the rear and its constant when driving, and as i have stripped the car it rather prominent.
I havent changed the rear stabilizer bush but i have removed it and greased it up etc but i cant see it being that.
Enjoying life
You sure the exhaust is centred in each triangle? Mine moved on one side and knocked continuously.
So i had the backbox off today, and the knocking noise was still evident. cut some of the arch liner as it looked to be rubbing against the chassis, replaced a few push ins.
Fitted a milltek, can only slightly hear it, but its still there:crying:.
