Hi there ABP, I recently bought a set on FSD's from someone on the forum and he mentioned that you had fitted them. I think that later he added KW springs which lower the iCDTi by 20mm, as the mileage he stated for both is quite different I am not sure if you fitted these.
But I just recently came across this comment "The official line from Koni is these are designed purely for use with normal height springs. Using lowered springs will affect the performance of the shocks negatively. (Statement from Koni's UK distributor)".
So I am wondering, any idea how the FSD are negatively affected? I still have the std springs and was thinking of refitting them due to clearance issues, mainly over speed ramps ie the suspension seems too soft at the initial compress. Though at speed the cornering/agility is greatly improved, sharper with body roll controlled very well. It would be a shame to lose this going back to std ride height, but not sure how much is the springs or the dampers.
Ride is pretty smooth over rough roads, not crashy, feeling the stiffness increase over larger bumps/dips and ,of course, in the corners.
Any advice would be welcome. Thanks very much.
Stefan
Stefan
