1 - 13 of 13 Posts
無限 Unlimited
Discussion Starter · #2 ·
Update: Denso part number in that link states 211200-2520.
However part number on the primary O2 sensor I unplugged from my car last weekend is 211200-2670.
GC
Mine was duff, got the hesitation and Vit spotted a static reading under WOT which is a tale tale sign apparently. Got replacement from Tegiwa, still got old one for some reason.
Weird yours says made in Spain, sure mine said Japan.
無限 Unlimited
Discussion Starter · #4 ·
Yeah I was expecting Japan to be written on there myself.
I had a bit of a dip in idle other day and it prompted me to take a look at the sensor and give it a clean, so tried the old white vinegar trick Ash posted a link to some time ago.
Before and after
ImageUploadedByTapatalk1352763355.383480.jpg ImageUploadedByTapatalk1352763370.130449.jpg
forgot to do a 'before' data log but the 'after' showed it was still working thankfully :)
無限 Unlimited
Discussion Starter · #6 ·
Ah cool, I should try cleaning my old one, might be handy in a tight spot.
Cleaning won't guarantee it'll work as it may be completely burnt out, worth a try to see if it can be revived though ;)
Before and after
View attachment 81256 View attachment 81257
When you say a dip in idle do you mean the engine speed dropped? Was this from cold?
If from cold then the cal should be in fuel status 1 (open loop) due the sensor being cold. So the sensor wont be causing it
Ive noticed my hybrid cal hunts around on cold idle a bit compared to my race cal. Both cals have the same settings.
無限 Unlimited
Discussion Starter · #9 · (Edited)
The dip actually happened when warm just once randomly (roughly 950rpm down to 750rpm for a split second) one day then a few days later noticed the same happen while pulled up to lights. Being conscious of needing a healthy lambda I thought I'd take a look last wknd.
My datalog after cleaning showed the A/F ratio move from approx 14.5 to 10-11 when accelerating (no delay) so looks to be working. But decelerating foot off the gas it read 29:1 ... I've assumed that's normal for now but I'm no expert tbh.
aka Paul
Good info/links guys. Cheers :cool:
So Laney cruising at 14.5 ( 14.7 is perfect) them to 11 on Wot (perfect for FI) if I read it right.
Closed throttle that reading is OK too btw
Thats all normal. Nothing to worry about.
Reactions: Laney
無限 Unlimited
Discussion Starter · #13 ·
Cheers guys nice to have confirmation :) thanks
1 - 13 of 13 Posts
