1 - 20 of 21 Posts
Has anyone got a decent intake hose or pipe which will fit the larger throttle body? I had oem and it split then got fd2 pipe and that split as well!
I would like a solid one but a silicone one would do!
翻訳中に失わ
I would recommend Meerkat Exhausts (01505685235) who supplied this stainless custom one for approx £120. It works very well with the Mugen TB and intake running 245bhp with no problems. You just have to get the samco coupling/breathing hoses and jubilee clips to go with it which I sourced from ebay....
翻訳中に失わ
^^+1 3" SS pipe, Craig of course admires me so much he decided to copy me :p lol
Says Dave who holds on to my bnib stoptech brake pads for a year as the centrepiece of his candlelit Craigy shrine.......such a weird boy :p :lol:
Either the HKS pipe or the Meerkat one will do the job nicely
poor pic but i've also got a meerkat pipe - powder coated black though :D
COTM Feb 2012
I would go with the metal ones, the silicone ones I believe can bend causing a bad restriction, especially at RRC angles..
The meerkat pipes are they to order or do they stock them?
They are to order. Good guys to feel with though and good product.
Sent from my GT-I9100 using Tapatalk
Just need a couple of samco connecting pipes from demontweeks and hose clamps to fit it
I am considering a SS pipe from Meerkat the only thing stopping me is that I plan to go Rotrex later this year/early next would the postion of the TB change when attached to the charger meaning I would need another one?
Discussion Starter #17
What size hoses and clamps do you need!
I used...
2 of these:
Samco 76mm Long Silicone Coupling Hose 76mm Bore In Black
1 of these (which I might have some left but will have to check):
Samco Air & Water Straight 1m Length Silicone Hose 16mm Bore in Black
and 1 pack of these:
70mm-90mm PRIMA steel stainless hose clamps clips x4
Discussion Starter #19
I have ordered a intake pipe from meerkat! Do I need the breather hose or will the oem one work?
any link where you made your order? thanks!
1 - 20 of 21 Posts
