1 - 13 of 13 Posts
hi i got a 2.2 2006 civic, only had it just over a month and the display on way home tonight had bits (pixels) missing is this a common problem is there a way to reset. Is it the actual display that is broken or the headunit.
Hi, mine has the same problem,i have everthing showing all at once.:confused:The problem does come and go though:(, I have been told that the head unit is on it's way out:facepalm:
Happened again today just some of pixels missing so the 8 now looked like a 6 etc. Gave dashboard above display a tap and all worked again, I'm now thinking a possible loose connection.
I have fixed two of these in the past on different cars. Both were caused by a dry soldered joint on the input connector, effectively a bad connection.
First step would be to remove plastic panels and jiggle the cable, see if that has an effect.
Audio equipment is usually excluded from warranties, at least with used car warranties anyway. Worth a try though - you really don't want to get a quote on a new headunit, a Euromillions win would be needed to replace
Deluded FK2 Owner
Has anybody posted a guide on how to remove the LCD display? I'm guessing I don't need to remove the head unit to get it out to see if it can be fixed with a bit of soldering?
1 - 13 of 13 Posts
