1 - 14 of 14 Posts
Hi guys,
My first post.
Now that winter is coming and we got the first (plentiful) rain in the sunny and dry Malta I discovered the infamous water leak in the boot. After some investigation I clearly saw the water coming in from the tail lights so I tried to find gaskets but they are expensive and quite difficult to find in Malta.
Here are my driver side gasket with two huge cracks.
314591
My solution was a cheap DIY using a trekking foam mattress from Decathlon for 4,99€ (around £4,50) which will be enough to fix all the gaskets on your car. it is foamy and the silver side has a bit of plastic which will seal the area quite well.
314595
314592
314593
314594
It was so good that I decided to inspect the other side too, I found another crack and I changed it. All for less than 5€
i-Vtec
Let us know how it works out for you. Cant imagine you get many rainy days in malta though, lol
Welcome to Civinfo btw (y)
Dunno about that, went there in January 1991 and had the biggest thunderstorm I've ever seen.
Sliema seafront was under about 2 feet of water.
Update
After testing the fix I found another water leak underneath the perspex window. Reading old threads I found a very helpful post by @Chapster pointing out that water usually comes from the edge wings of the perspex window. I literally injected from inside the tailgate with a silicone gun and a transparent tube attached to it in the area with the green circle.
Attached images provided by @Chapster and @dkkirk2016
Waiting for the silicone to dry for a second round of testing. Also I decided to buy a Captain tolley's creeping crack cure tube and fix every potential leak.
Cheers yeh I used captain crack sealer worked a treat I don't dare to inject the tailgate lol how did u reach the curved part I'm very interested because I haven't done that part? Any pics
Sent from my FIG-LX1 using Tapatalk
I used a transparent pipe attached to the silicone tube. Then I cut the tip of the pipe in needle shape and I injected from inside the tailgate. The whole edge wing should be now filled with black silicone.
I will post the test results tomorrow when the silicone has hardened. Wish me luck :D
✅ Test passed!
I got some help from mother nature yesterday evening, we got a huge thunderstorm. I sat inside the car for 20 minutes and not even a single drop managed to get in from the tailgate where I used to have a hotel spa.
Injecting the silicone worked like a charm! 😁
Now I've just got to find some tubing for mine now lol what silicone did u use!
I used a multi-use black silicone. The brand is Geocel.
I read it has very good results on sealing water leaks on windscreens, caravans, underground pipes, and it bonds and seals any surface.
I've used clear Geocel on my previous Civic around the headlights and other places and it wasn't good - crumbles and gets yellow. Black could be better though.
Tigerseal is another good option.
Discussion Starter #14
Here in Malta the real problem is the 300+ sunny days per year, that's a lot of radiation. Even if the silicone is "protected" underneath the tinted area of the perspex window I don't think any silicone will survive so many hours of UV and temperatures of above 70 ºC in summer.
I am quite aware I will have to fix it again in a couple of years.
1 - 14 of 14 Posts
