On my FN2 I have water leaking into the passenger foot well. I know it's not from outside and as I have done the processes of elimination it only happens when the air conditioning is on.
The drain pipe appears to be clear and correctly attached. Is there a chance that the pollen filter being filthy would have anything to do with it? This is getting rather frustrating. Does anyone have any suggestions and photos of the condenser inside the car?
Thanks in advance.
Get a hoover in the pollen filter area properly. Take out the filter and snake the pipe leading from the bottom of the car up to the footwell area as youll find its clogged with silt and causing the leak
I took the pipe off and blew it but it seems to be totally clear...
The pollen filter box is also clean. I did read that if the filter is so dirty it doesn't let moisture through so is just soaks it up- unless I got the wrong end of the stick.
Oh really? I've never heard that before, thank you. But even if that's the case would it not still drain where it should?
