Hi!
A couple of things that hopefully one of you lovely people can help me out with.
1. I have quite a bad leak coming from this (below) black tube. Can someone shed some light on what the tube is for, and why it would be leaking quite badly?
2. This is my friends Civic that I was trying to compare to work out what the leak was. As you can see he has a large panel of metal on the underside, now I presume this is just to stop anything bouncing up and damaging anything? If so, is it important that i get it replaced?
Thanking you in advance! :)
That's normal mate, its the pipe from the aircon system. It's the water removed from the air in the cabin during the cooling down process. The cold the air temperature the less water content.
Hope that makes sense,
Gaz
