Has anyone found a solution for a creaking noise from the air vent at the left end of the dash? Seems to be the right side of the unit rubbing on the opening in the dash, somewhere inside. I've stuffed material in between and used silicone spray but the noise always comes back. A while back, 'wheelchair' mentioned that a new vent was ordered but the thread ended there. Did this solve it? Thanks in advance for any help.
Check the glovebox, mine wasnt fitted quite right and creaked from new, sounded like the airvent area but wasnt.
Thanks for that but deffo the vent as the noise stops if I put some pressure on it. I could get a new vent fitted but it might start a string of events like has occurred in the past.
Never tap!
the noise i had was from the behind the steering wheel and when pressing down the noise was removed. I wedged some double sided tape in a hey presto its gone :eek:
