Veedub
Just wondering if I can load music I have compiled onto my HDD via a USB stick, or is it just by slotting in CDs. Can't see anything that relates to this in the Manual
Yes, it reads and copies the CD whilst it's playing (if you have that option selected). from what I understand it has to be a commercial type CD in .CDA format and not .MP3 tracks on a CDR.
The one snag with the HDD is that it only plays one album then goes back to the start of that album, or that's what I've found.
If it only did the same as USB and just plays all tracks/albums from start to finish.
agree with what Kremmen says. Easier just to ignore the HDD and load everything on to a USB stick.
Reactions: Nitehawk
Veedub
I'm working around it by condensing CDs into MP3 format... Maximise a CD and yep.... It seems to be working..... The frustrating thing is we are always looking for fixes for different things Arggghhhh!! I couldn't find anything to do with the HDD in my manual.... That is poor or am I going blind
Q:
So once the MP3's are loaded onto the HDD do they play from start to finish of the whole HDD ?
At the moment (apologies for music choice) :p I've got just over 100 singles on the USB in a folder. That is followed by another folder with all the Moody Blues albums and that is followed by a few more folders with other albums.
The USB plays all the singles followed by all the Moody Blues albums followed by all the other stuff in the order I set them. When it gets to the end of the final album it start again with the singles - I don't need to touch anything - perfect.
When I tested the HDD I loaded all the Moody Blues albums. It played the first album and instead of going onto the second one it just started the first one again, even though I had them in a playlist. I tried a few ploys but none worked.
= back to USB.
Must have been a change to the HDD spec as this didn't work when I tried it in my 2013 car. Good news 'tho
Would be great if somebody discovered a way to load the HDD directly with mp3's - even if this meant removing the disk and putting it in a caddy to connect directly to a pC
Reactions: Nitehawk
Veedub
Ok.... When I first got the car I just played either my compilations or pre-recorded CDs and then easily switched to USB if I wanted complete albums, (I'm a mug for Queen and ELO). When I first got the car I was travelling around for long periods and realised that I didn't have a CD in it all and the HDD was playing all the tracks from different compilations that I'd shoved into the CD slot previously. So I thought I'd try the whole process again so I deleted everything on my HDD then made up another compilation which I'm playing over this past few days, I switched over to the HDD yesterday and those tracks were on there... Soooo I'm getting what I want from it which in this case is a whole mix of music not unlike these Now that's what I call music albums. It just seems to take time with a CD where as a USB does things so much quicker..... I hope it makes sense here because this is exactly how I'm doing it. (ps. I also shuffled everything on WMP before I started recording)
Reactions: Slider2
