1 - 16 of 16 Posts
Hi. I have a 1.6 dtec EX on order, which comes with the HDD audio.
I have a large collection of mp3 and WMA music files that I intend to store on the hard disk.
Question is, can I transfer these via a USB port using a USB stick.
Failing that can I burn to a DVD and transfer that way.
Now the bad news ...........
The only way to put music on the HDD is to 'play' a standard audio CD. Whilst playing it loads it onto the HDD at about 4x
Save yourself the hassle and just load your music onto a USB stick, works far better IMO
very bad news indeed as the vast majority of my music is in digital only format. I had envisage loading all on to the HDD but looks like I am going to have to invest in a high capacity USB stick - questions the point of having the HDD really! :(
Not a big investment it is. +- 20€ here for an USB stick of 32 Gb.
Success
Greetings,
Dark Flemish
yes, I know its not a lot of money - just the principle really. USN stick contains data, HDD stores data, surely it can't be so hard to create a system that transfers data from one to the other. Would be so much tidier is I could have stuck every thing on the HDD and played from there.:worms:
It has more to do with drm concerns of the music industry than the technical capabilities of the system.
I did load quite a few CD's onto the HDD and it does work OK. If Gracenote has your CD listed you can see the track and album info. If not you can enter it manually (a pain).
what I didn't realise until I started playing via the HDD is that at the end of the album it doesn't progress to the next one but starts playing the same one again.
When I'm driving I don't want the distraction of selecting the next one manually.
The USB option however just plays all the content from start to finish, album after album, which is far better.
Kremm
On the audio buttons on the steering wheel Hold down the left or right hand button on your steering wheel and it will move to the next music folder which ever directional button your holding.
Thanks for the info :)
I've now gone back to USB as it performs exactly as I want it to. I'm not fussed about seeing album/track info as I know what I've recorded and I just want to listen to it.
Like others have mentioned, if I could load my MP3's to the HDD and it just played them one after another I'd use it.
As would I but for some reason when loading from an audio CD onto HDD, it doesn't seem to record them in track order as per whats on the CD... this irritates me when I know in my mind the track order of a CD.
+1
As other said. not worth the time and effort. I loaded about 20 CD's (Mainly because I've not got around to getting them in digital format) and gave up.
As per the others, I now have a 32gb USB stick with most of my music/iTunes stuff on... more than enough :)
I guess it's not actually a HDD but just 16GB of memory in there with 10GB available for files, but I like others, just moved my 16GB USB drive from my old civic to the new one.
Strangely though, it didn't recognise all of the files like the old Civic, only 255 out of the 1400, turns out it has some kind of limit....so I put them into alphabetical folders.
Puzzles me why my 8th Gen was happy with them all in one folder and the 9th Gen isn't but with the more advanced interface having them in folders has proved useful anyway.
It's a shame the HDD wasn't implemented better. Whilst the whole unit has some new welcome features it could have been a whole lot better with some thought.
Single button for SatNav voice on/off
HDD plays like USB (album after album)
Switch air vents/SatNav position to raise it
Discussion Starter #14
DRM issue is a bit of a cop out really. Surely it's no different from loading mp3's directly on to the hard disk on a computer.
Anyone know the make/model of the premium audio unit? Pretty sure somebody somewhere will have discovered a work round or jailbreak
Anyone else like having to press OK to the warning info every time they use it?....I do....not all annoying......!!!!
I agree, but car makers are so scared of litigation.
1 - 16 of 16 Posts
