Woo frakkin' Yay
I tried searching but was unable to find a clear answer or the images in the threads were all broken so not much help.
I am trying to install a second circuit to my Civic Type S 07 plate. I have successfully worked out how to hide all the wiring behind the dash and A-pillar but what I can't work out is how to power the damn thing.
I have the following:
1 x micro blade fuse tap
1 x hardwire mini usb cable kit
The red wire is connected to the fuse tap via crimp connector I get that. What I don't understand is what I do with the black wire. Presumably it must be connected to a suitable ground point in the car but I looked under the footwell and was unable to locate one. Without that the device won't work.
Can anyone help locate a grounding point in the front of the car?
yes, it is located above your knees
Look at pics 4, 5 and 6
http://www.civinfo.com/forum/how/109014-how-hardwiring-dashcam.html
Fox can also kinda tell you are hard wiring a dashcam due to the hiding the cables behind A-Pillar and mini USB connector step down conveter
It also shows a more simple way that does not need those annoying "add a circuit" things
Woo frakkin' Yay
I've now successfully found a ground point and its working. However I didn't have a mini spade connector so tried the fuse tap method. However when I use the tap there seems to be power going to the device all the time. Is there a particular fuse socket that's only live once the key is in the ignition? Thanks.
Have you connected to bottom left or right of the option connector? Bottom right is ignition and left is permanent!
