Fitted a CHL module and woks fine. The only issue is that the signal for this module is wired to a cable which receives ground when the interior lights are switched on. I would like to modify this and wire it to some cable that receives earth when the car is unlocked.
Any help pls ?
Module is made like this that current wire from interior lights has 12V and when lights are on it 0V (or gnd) which triggeres module and there isn't any wire like that in car as far as I know.
What your asking if I understand correctly is you want just unlock and lock to activate module? If yes then you need "standard" chl module. Not sure what problem is since as I read and saw on video module activates when car is unlocked.
Standard module would be one which is connected only to central locking and is triggered by it. So it will only work when you lock or unlock car and won't depend on the interior lights like the one you now have.
To modify current one isn't really easy job.
This is what you need
