Had rear callipers changed and new brakes and pads all round. Now the pedal seems to travel along way before the brakes bite. What could be the problem? Cheers
Sent from my VOG-L29 using Tapatalk
i-Vtec
Did you pump up the brake pedal and pump the handbrake up after fitting them? Also as you have only changed the pads, and not also the disc's, the new pads don't have full contact on the disc until the pads bed into the disc's. Old disc will always have groves, and wear, until the pads bed in the brakes will have a soft feel to them.
Definitely sounds like air got into your brake lines. Try bleeding them. You can usually get a kit (tube and container) at auto parts stores. Buy some DOT4 brake fluid too.
Sent from my VKY-L29 using Tapatalk
brakes can tend to be soft after replacing them
if they work just try after a day or 2 see if they get better
why did you change the rear callipers
maybe a issue elsewhere does the civic have a compensator valve
If you've changed the rear calipers you must do a full bleed. All corners need bleeding. I use a pump and suck the fluid from each bleed nipple, saves having someone pumping and closing and opening the bleed valve, however I have someone watching the brake fluid resevoir.
