I've noticed the door handle seems to be loose, and want to tackle the problem before it gets any worse.
I did read that people have just used epoxy to secure it. Has anyone got instructions on opening the door card on the passenger side and also where I need to glue this thing?
Any help is much appreciated.
The epoxy 'fix' is (afaik) and as far as I've done on mine, just for the loose handle trim.
If'n you're taking the door card off to fix a loose handle would it not be more prudent to fix it properly
OK, so it's just to apply from the outside around the edges of the trim?
It seems it's more the trim around the handle that is loose, although when pressing the handle to open it isn't as smooth as it used to be, I was putting that down to perhaps the trim moving
If it is just the trim then a few tiny dabs on the inside edge will secure it.
But if the mechanism is playing silly buggers then it might be worth the time to have the door card off and check & lube it up
