Good evening!
I'm brand new but I've been searching for an answer to a problem I've got with my beloved Honda Civic. I've been over the forum and can't quite find the same issue so forgive me this first info seeking post (v ride I know, but I'm desperate!)
Car: Honda Civic
Reg: 55
Diesel
2.2 CTdI
5 door hatchback
It's got full service history etc and been brilliant until recently.
I switch it on it drives just fine for a few miles then after a random number of miles (between 4 and 6) it just loses power. I am usually doing around 30mph, steady, not changing gear. Then the revs just die. They get stuck at just over 1,000 rpm. No amount of repressing the accelerator will bring the revs up. I can change up or down the gears and that changes the revs a bit but gradually the car just slows until I can't move it. I can't rev it, I can't make a difference switching gears, it just slows to a stop. I can leave it a bit and restart but I can't get much past 5-6 mph then after a while power returns randomly (this could be 20 mins and it still juddery but I start to get speed back).
I get no dashboard warning lights at all. It will start. The engine turns, it just won't go.
Honda have seen it and can't replicate the fault (not sure why, it's happened to me every day for the last fortnight).
Initially, they considered slipping clutch but ruled it out.
They considered new injector seals for a misfire and a new fuel filter. I have had this done. If anything it's worse.
Nothing is showing in the diagnostics.
I've broken down again (Honda can't take it to look at again til April 8th) another garage can't see anything wrong with it.
I am at a loss as to what to do! Is there anything either garage may have overlooked? Is there anything I can check? I basically can't drive it!
Thank you for your time reading this! Any questions I'll do my best to answer, any advice much appreciated.
Car: Honda Civic
Reg: 55
Diesel
2.2 CTdI
5 door hatchback
