1 - 20 of 20 Posts
· Premium Member
hi all is there a way of knowing if your car is fitted with LSD ??? i own a 10 plate ctr purchased in april 2010 so will my car be fitted with lsd ????? is there some way i can go look for myself to see if it is fitted with lsd bearing in mind im not mechanicaly minded
***** : mike
· Premium Member
I've read some were cats from may 2010 onwards have them, but I'm not sure,
Other way is Ho I a car park and get it to wheel spin, two lines means you don't have it, and one line means yoh have It, I think I've got it the right way around , :/
Can some one confirm
· Premium Member
Cars manufactured in and after April 2010 had a LSD. I.e. the last production run.
If you wheelspun with a LSD it would leave two black lines. That's the point of it. When one wheel starts spinning, due to its mechanicals it sends power down both driveshafts. That's why you corner better.
With an open diff it sends power to the wheel that is easiest to turn, which is the wheel that is already spinning.
Dealer will be able to tell you probably from the reg, but definitely the VIN. They need to be able to tell on the parts system when you have, say for example your gearbox breaks, so they can order the right parts for replacements.
To be honest, if it was registered in April I doubt it.
· Premium Member
So why has this one stated my09????
i think so he can rule it out immediately if it says my09
Reactions: lloydy_1_1_1
· Premium Member
Discussion Starter · #10 ·
the number at thd bottom of your windscreen will tell you the year it was made so if its my09 you neednt look any further!
where on the windscreen all i have is my vin number and that says 10 ??? is this the number your referring to ????
· Premium Member
Discussion Starter · #12 ·
yes mate if it says 10 then theres a better chance
so all i have to do now is go to honda and ask them if my car has lsd ??? is that correct ???
· Registered
im not flaming you for that one mate! but if someone wanted to do a trackday and then drive in a manner that would benefit from lsd it might save them some money!
well... it does matter, if you was to say, sell your car privately, im sure that might a question the buyer might ask
To be fair they are both valid points.
I guess were i'm going with this is: 'keener' drivers would know if the car had a slippy diff after the first wet round-about or quick pull from a T-junction. :worms:
· Premium Member
Discussion Starter · #18 ·
and maybe some of us are to old to be boy racers lmao ha ha ha ha ;););)
1 - 20 of 20 Posts
