1 - 2 of 2 Posts
I-Vtec... Do you?
Hi everyone as you can see from my other thread Im doing a ICE install I was just wondering what MDF thickness I need for rear speakers so they have enough clearance if you need to know what speakers I got I have some infinity ones I can add a link if needed
Thanks for your help also front thickness would be handy to know
無限 Unlimited
You need to measure the depth of the speaker you're fitting first really as every one is different and also the shape of the basket varies. When I fitted mine I did a test fit on one side quickly to give me an idea, it doesn't take long to remove the rear trim so go for it :)
However between 12-18mm thickness should be good for most.
Reactions: Dwyer9
1 - 2 of 2 Posts
