I've just had to get my first tyres, and decided to go for Michelin Energy to keep them matching. At 51k on original tyres is pretty good, rears still have 4.5mm, and fronts at 2.5, so decided for some more up front.
They were rotated at around 20k... hence lasted so long.. but still unbelievable wear rate....
i-Vtec
Michelins are the best tyres Ive ever had. I had about 40K, and perfect wear, from a full set on an Accord Mk5. The only issue with doing that sort of mileage is you need to watch for dry rot and cracking, especially between the tread blocks. BTW you'll get slagged rotten for admitting to putting new tyres on the front around these parts.
I didn't put them anywhere, the tyre fitters did... but it really doesn't make much difference unless one set are very worn and you can't drive.
