1 - 20 of 248 Posts
Ανοιγω αυτο το thread σε συννενοηση με τον Skam για να δουμε πως γινετε η εγκατασταση του module για τους καθρεπτες που πηραμε με group buy.
λοιπον ξεκιναω με το manual και μετα παραθετω οδηγιες για reset σε περιπτωση που καποιο δεν δουλευει.
επισης θα μεταφερω και τα email που μου στελνει ο πωλητης για να βλεπετε τι λεει
Discussion Starter #2
το original καινουριο manual που πρεπει να ακολουθησουμε
οι οδηγιες για τα reset ειναι οι εξης (στα Αγγλικα οπως μου τα στελνει για να μην κανω καποιο λαθος στην μεταφραση)
and we can do a reset to the controller in 2 ways:
If you gonna have the same issue you cannot open or close the mirrors ( of course the door button should be in open/ upper position) than the first option for reset is :
Press the remote controller's close button eleven (11) times, this will resets the chip, and the mirrors should fold or unfold depending where they were previously.
If solution 1 is not working, then here is the second solution:
Check that your two front windows are in upper position, than open the bonnet and remove the fuse #6. (40A) from your fuse box place under the bonnet ( near to the ECU) wait 3 mins and put back this is another reset and it should works properly ( of course if the door button of switch is in upper / open position)
In emergency:
If you cannot unfold the mirrors (but you have to go with your car)with the key or door button then follow this:
Remove the fuse number6(40A) I mentioned. Put the key in and turned it the mirrors will go out that's sure!
After this you can put back the fuse.
If you have time the "big reset" of the controller is to remove the fuse for 5 mins after you can put back and souls works normally!
If not then the ic damaged somehow but this couldnt happen with issue you discribed because if it damaged then is not working at all. And not sometimes yes sometimes not....
the 5 mins fuse out will reset the module for sure.
Πιο αναλυτικα
unfold the mirrors with the button (button should be in upper position) in your door (of course the key must be in and turned)
2 remove the key
3 open the bonnet
4 remove the fuse
5 wait 5 mins
6 put back the fuse
7 now close your car with the remote, press twice the close button (deadlock)
8 the mirrors should works and fold in
9 wait 30seconds
10 open the car
11 step in
12 put your key in and turn it
13 your mirrors will be unfold
this is how should operate!
the opτions below were provided for emergency, which means if you have folded mirrors and they don’t open whatever you do.
this means:
the fuse #6 gives 12V for controller, if you remove this you gonna have EXACTLEY the same situation as before you had w/o any controller installation. your buttons should works as worked before!
So if your mirrors are folded and the fuse is removed your mirrors will unfold automatically once you put the key in and turn it, of course if the button of the mirror on the door is in upper position as usual.if you press that button the mirrors should fold in.
long story short…if you remove the fuse#6 (near to ECU, and not inside the car, at your leg!!!!) will eliminate the controller (you will go back in the past as you never installed that in your car) with this situation your mirrors should works as before, same as you bought from dealer….. (of course your windows won’t working because you removed the fuse of it)
BUT if you don’t put back the fuse immediately and you wait for 5 mins the controller will reset, because inside is a capacitor which will discharged!
the manufacturer tested the units again and he is sure that this 5 min.break (controller w/o current 12V) will solve your problem cause by the capacitor!!
pls check out and come back!
now the manufacturer said that the controller can be instable!
which means sometimes works if you press 2 times sometimes if you press 6-7-10times the close button!
Now he is working on a solution!
If we have a solution (like we send a diode for you with instruction) we will do this if not you have to send back the units and we fix the problem!
τώρα ανακάλυψαν ότι μερικές φορές είναι ασταθές;;;; τις οδηγίες που έστειλες δεν βλέπω να τις δοκιμάζω πριν το σαββατοκύριακο καθώς το κιτ έχει αφαιρεθεί από το αυτοκίνητο.
ξεφωρτιζει ο πυκνωτης λεει και αν ειναι να τα στειλουμε πισω....
ειπε οτι τα δοκιμασε ενα ενα.
απο τη στιγμη που αυτο το πραγμα κοστιζει κατι λιγοτερο απο 10 ευρω, και ειναι 50-50 οτι θα δουλευει, ποσο μαλλον και το οτι η αγορα εγινε απο καποιον αγνωστο στην Ουγγαρία
θα επρεπε η τιμη του να ειναι το πολυ 20 ευρω.
τωρα θα ταλαιπωρουμαστε αν δε δουλευουν εστω και τα μισα.
αν πρεπει να τα στειλουμε πισω τι γινετε αν βγουν απο το αυτοκινητο? θα δουλευουν οι καθρεπτες και το κλειδωμα?
και αντε παλι μετα να κολλας ξανα καλωδια να ξηλωνεις καπλαμαδες.....
προτίνω να του στείλουμε ένα mail, με εντονότατη δυσαρέσκεια ζητώντας να μας καλύψει τα μέχρι στιγμής 3 ελατωμματικά (ας βάλουμε και του genesis) και να στείλει και κάποια επιπλέον για τις επόμενες εγκαταστάσεις. Αυτά που θα είναι οκ, θα του τα στείλουμε πίσω.
Αν στις 6 εγκαταστάσεις τα 3 ειναι off, παίζει με μεγάλα ποσοστά αστοχίας.
アレックス
Εγω καταλαβαινω οτι το module ειναι γτπ...
Το εχω παρει και εγω δυστυχως, αλλα δεν θα ρισκαρω να βαλω στο αμαξι κατι τοσο χαμηλης ποιοτητας και αβεβαιης λειτουργιας. Ποσο μαλλον αν αυτο ειναι ηλεκτρονικο... :(
αυτα που θα ειναι οκ γιατι να τα στειλουμε πισω??
εγω λεω να περιμενουμε οσο περισσοτερους γινετε για να κανουν την εγκατασταση και να του στειλουμε πισω αυτα που δε δουλευουν μαζι με ενα mail και να μας στειλει αλλα δωρεαν προς αντικατασταση!
αλλα πρεπει να μην αργησουν οι υπολοιποι να κανουν την εγκατασταση
τουλαχιστον οι μισοι ή το 1/3
είμαστε ήδη στο 1/3 σχεδόν. 22 πήραμε, 7 κιτ δοκιμάστηκαν, εκ των οποίων τα 3 έχουν πρόβλημα.
βασικά να στείλει άμεσα 3 με δικά του έξοδα προς γνώση και παραδειγματισμό :p
Διευκρινήστε το θέμα των μεταφορικών για να μην βρεθείτε προ εκπλήξεων.
Επίσης προσοχή γιατί τώρα μπορεί να λειτοργούν αλλά μετά από 2 ή 3 ή 6 μήνες;
Πόσο θα σας καλύψει από εγγύηση;
Αυτο ηθελα να το πω και εγω. Οπως.και εμενα μου δουλεψε μια μερα μπορει παλι τα καινουρια να σταματησουν να δουλευου μετα απο λιγο. Η ακομα τα ιδια να τους κανουμε reset και να δουλεψου και μετα να τα παιξουν παλι....
οκ... να προτείνω κάτι άλλο; όποιος δεν θέλει να γίνει επιστροφή του κιτ στον πωλητή και επιστροφή χρημάτων
δεν ξερω τι να πω, τωρα ειδα κι εγω το μαιλ που μου έστειλε και το νεο θρεντ που ανοίξαμε, τι να κανουμε δλδ να μην δοκιμάσουμε καν αν λειτουργεί να τα στείλουμε όλα πίσω? γμτ να μη πω τι...καλα κρασιά τωρα!
Κώστα αυτό έλαβες κι εσύ?
Hi Guys,
sorry I have a bad news!
It seems the IC which are in controller is bad. There was a process improvement regarding the response times (nano seconds) and cannot be use in this environment without filters
Now I spoke to manufacturer and we agreed that he will replace with good ones.
Of, course as I said the controllers were tested into test pad but car, and the cars other signals , noises of electronic equipments “disturb “the controller’s chip!
Actions:
Pls send back all controllers to me in one shipment!
Once I receive it the guy will modify all of them and I will ship back to you ASAP!
Very-very sorry for this, but never thought that this kind of problems occurs….Testing environments are not the same of the car’s environment so this was the problem!
When can you collect all of them and send it back for replacement?
thanks and sorry again!!
P R E P A R E D
επιστροφη και αμεσα....
αν δεχονται ο Χαρης ή η Αναστασια ή σε εμενα ή σε καποιον αλλον να γινουν δεκτες εγχωριοι,και αποστολευς στο εξωτερικο
για επιδιορθωση
επιστροφη χρηματων
ειναι χαζομαρα να κολησουμε στα μεταφορικα εξοδα για μια τοσο καλογουστη εφαρμογη
δεν έχω πρόβλημα να το αναλάβω μιας και έχω μεγάλο μέρος των κιτακίων στην κατοχή μου.
Power of Dreams
Παλι 3 ωρες θα κανω να σε βρω! :Ρ
Εγω παντως δεν εχω προβλημα να το στειλω πισω, ουτε να μοιραστουμε τα εξοδα αποστολης.
1 - 20 of 248 Posts
