I’m currently doing a halogen to led retrofot on my 2015 civic.
There is no guide or how to on the forum so hopefully this will help someone out.
there is thread where a member is asking for how to find the led driver plug. As luck would have it a member had found the part numbers for the plug and the pig tails.
I bought a set of headlights from eBay and ordered the plugs and pigtails from my local Honda dealer
The member who started that thread has done the retrofit but he got a garage to do it so don’t know how it was done.
This is the halogen headlight
This is the led headlight
The indicator and the side lights seem the same as the halogens so no problem there. Should be plug and play
The main beam however to totally different. It has a led driver with a 3 pin plug and the halogen light has no plug specially for the main beam.
The halogen light has 8 pins on the main plug and the led light unit only has 7. I think this is because the extra pin is for the power on the main beam.
here are some pics
Here’s the back of the halogen light
the back of the led light
here’s the led driver plug on the ledLight
the plug on the halogen. Has 8 pins
plug on led 7 pins
here’s the parts from honda
Discussion Starter · #2 ·
Here’s the loom made up
The green wire is earth and the yellow wire is power. The yellow wire with a hoop I think is for the levelling system
Here’s the light with the power connected and powered up
I will connect the power wire on the pin On the main harness which not used on the light and use a earth on the main harness
Not sure if I’m going to go down the levelling system route and don’t need washer jets as it’s led system and Honda don’t put them on the UK type r
I probably won’t fit them for a month or 2 as the car is having other work done. When they are on I will update this thread.
Discussion Starter · #3 ·
Here are the part number for the plugs and pigtails taken from another post. My Honda dealer charged me £35 for all 3 parts.
connector 04321-T2A-305
With Pig tail terminals 04320-T2A-B00 & 04320-T2A-C00
I would love to make this upgrade to mine but i guess i will sell my car next year so not a priority by now.
Please let us know more updates :)
@G10 did you finish this project - any additional info? did you fit the self levellers?
